TwinTurbo.NET: Nissan 300ZX forum - Only issue with that is it would mask a problem. If there
Subject Only issue with that is it would mask a problem. If there
Posted by Ash's Z on June 20, 2007 at 4:36 PM
  This message has been viewed 60 times.
In Reply To I always wondered why the MAF wasn't just before the posted by audioquest on June 20, 2007 at 04:15 PM
Message are leaks in the intake piping after the turbo, the turbo has to work harder to supply air to the engine at a given pressure if there are leaks after the compressor discharge.
You wouldn't notice all the black soot coming out the tailpipe, but in a worse-case scenario, you would be spinning the bejeezus out of your turbos.
Bottom line: routinely inspect your vehicle for problems; 6 P's rings to mind. ;-)
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
